How to delete project from designer
Hi. I’m trying to delete an old project from the Designer launcher but can’t see how to. See attached pic where I want to delete the A_PROJ but keep the other one.
On your gateway, go to Config/Projects. There’s a delete option underneath the “more” drop down of actions.
Brilliant. I knew it would be easy, just didn’t know where to look.
Thanks.
@ijustdunnoaname1 is correct; there is no option to remove a project from the launcher or the Designer itself. The Gateway is where project removal should take place.
You’re looking for this area here:
Screen Shot 2020-06-03 at 11.18.40 AM
Hello, I’m trying to delete a project but it’s not possible, I get this error:
I think that the problem is coming from a identity provider or/and real time tag provider issue but I’m not sure, the project is inheriting from a base project and other child project inheriting from the same base project are ok, I’m able to delete them without issue, but one project in particular is avoiding me to delete it. I’m also able to export and import the project with a different name using the Designer Launcher but the original project, event changing the name, I’m not able to delete it !
thanks in advance !!
Do you have any sessions open which use this project? Do you have any other projects with the same name, but with different casing? Do other projects inherit from this project? What version are you using?
Hi, I’m using a podman container to host my gateway, version 8.1.44 and I solved the problem deleting directly the project inside the container. I think that the problem is coming from the Tag provider as I cannot find it once imported, weird!… but anyways, I deleted and re-imported the project and voila, everything looks good now, thanks !
I also found this: Delete a project issue - Ignition - Inductive Automation Forum, very useful as well :wink: thanks again!
