How to derive the tag path from an alarm event
Given an alarm event object. Is there a way to obtain the tag path from that alarm. My alarm comes from a tag and I can get the 'source' property and this has the tag provider and the alarm name. I simply want the tag path for example '[default]My Tag' instead of 'prov:default/tag:My Tag/alarm:Test Alarm'
The source is a QualifiedPath object which has various structured mechanisms to extract data.
toStringSimple, perhaps?
Probably the simplest that gives you the representation you're looking for:
from com.inductiveautomation.ignition.common import QualifiedPathUtils
tagPath = QualifiedPathUtils.toTagPathNew(alarmEvent.getSource()).toStringFull()
Hi Paul, I just tried this:
from com.inductiveautomation.ignition.common import QualifiedPathUtils, QualifiedPath
tagpath = 'prov:default:/tag:Area A/Device 01/Level:/alm:High Alarm'
qp = QualifiedPath.parse(tagpath)
QualifiedPathUtils.toTagPathNew(qp).toStringFull()
and the result is:
u'[default]Area A/Device 01/Level'
But my expected result is:
u'[default]Area A/Device 01/Level/Alarms/High Alarm'
As this is the actual tagpath to that alarm, if you copy it from the tag browser
How would I produce that instead?
Also, is there any way to read/write the value of tags given a QualifiedPath object like above without converting to a string path?
Best I can do on short notice:
from com.inductiveautomation.ignition.common import QualifiedPathUtils, QualifiedPath, WellKnownPathTypes
from com.inductiveautomation.ignition.common.tags.config.properties import WellKnownTagProps
tp = QualifiedPathUtils.toTagPathNew(qp)
alarm = qp.getPathComponent(WellKnownPathTypes.Alarm)
if alarm is not None:
	tp = tp.getChildPath("Alarms").getChildPath(alarm)
print tp.toStringFull()
The underlying APIs can accept TagPaths, but there's no (easy-ish) ways to access or consume them from scripting.
Ok cool, that works, cheers :slight_smile:
Minor correction to the import:
from com.inductiveautomation.ignition.common import WellKnownPathTypes
