I have design a dropdown list, in upside picture the right side show on the label , and the left side line become the dropdown value.
when this mode in vision, I can get the both data from selectedvalue and selectedstringvalue this two components.
but in perspective, I can only find the left line in prop.value , is there some solution can make it similar like vision two value can be get in the property?
You can construct an array like this in a transform script, where value is an object:
returnData = []
for x in range(value.getRowCount()):
returnData.append({"label":value.getValueAt(x,1),"value":{"WareHouse":value.getValueAt(x,0),"ToPlace":value.getValueAt(x,1)}})
return returnData
Basically you have 2 options, if you are not interested in the int value you just need to filter in the String column you want.
- Manipulate the options dataset
Use a script transform in your options property:
And when ever you select an option you will see the string value
- Create you own property,
If you need the int value for whatever reason, you can create your own property stringvalue.
Use a property binding using the prop.value and apply a script transform.
the script in the transform is:
options = self.props.options
if type(value).__name__ == 'JsonifiableArrayList':
stringvalue = []
for v in value:
strvalue = None
for r in range(options.rowCount):
if options.getValueAt(r,0) == v:
strvalue = options.getValueAt(r,1)
break
stringvalue.append(strvalue)
else:
stringvalue = None
if value is not None:
if options.getValueAt(r,0) == value:
stringvalue = options.getValueAt(r,1)
break
return stringvalue
current status is like this, only 1 value can be read in the props
what I want is this picture, two value can be binding in the property, that can be realize by victordcq code
Hi, is it possible to have 2 items in the dropdown, I want in such a way that we do like in vision as list in dropdown, so we will see 2 columns in there, likewise is it possible to have 2 columns like label and value both in the dropdown UI, when we click on the dropdown.
No, not possible, it will only display a single string from the label property.
You'll have to format the labels string to include your second column
There is an ideas post for the ability to make drop-down elements into embedded views. This would give the desired affect you were looking for
