How to determine gateway startup and shutdown times?
Does Ignition have a functionality to determine the datetime of gateway startup and shutdown?
There is a system gateway tag called UptimeSeconds which you can use to infer the startup time. The shutdown time you could approximate as when the uptime was 0 i suppose.
You could also log to a db table using gateway startup and shutdown events.
Screenshot from 2022-03-15 07-03-34
Except the startup script re-runs every time you edit its project....
You can ask the JVM for it’s start time directly:
