Hi All,
Hope you all doing good.
I just want to ask how can I display in the table of my tag integer array values?
I’m a newbie in Ignition so bear with me.
Thanks a lot!
Hi All,
Thanks a lot!
I generally avoid array tags, but if you need to use one, this function may help.
def ArrayTag2Dataset(tagName):
Create a dataset using the name of an array tag
example: ArrayTag2Dataset('[Test]ArrayTag')
returns: tagName | value
[Test]ArrayTag[0] | 1
[Test]ArrayTag[1] | 2046
[Test]ArrayTag[2] | 8675309
[Test]ArrayTag[3] | 42
[Test]ArrayTag[4] | 73
values = system.tag.readBlocking([tagName])[0].value
headers = ['tagName', 'value']
data = []
for i, value in enumerate(values):
element = tagName + '[{}]'.format(i)
data.append([element, value])
return system.dataset.toDataSet(headers, data)
Hi JordanCClark,
Thank you very much.
-JR
