How to display smaller unit on gauge
I am trying to use the gauge for value display.
But the unit is displaying the same size as the process value.
Is there any way to display the unit a bit smaller than the value, better if it can sit below the value, same as the template below.
you can split it up with a new line
after that its not to hard to target the second element edit it with css
[data-component="ia.chart.simple-gauge"] g > text:nth-child(2) {
    font-size: 10px;
adding in text-anchor:middle is also nice, you'll have to adjust the offset a little tho
[data-component="ia.chart.simple-gauge"] g > text{
text-anchor:middle
offsetx 20 seems nice for 3 numbers
offsetx 14 for 1 and 2
Just noticed that you have done the round corner of the bar.
Can you advise how you did it?
props.arc.cornerRadius
Thank you. it works.
