How to display tag in table in ignition perspective
want to show real time values in a table
Where are you getting your values from? If you’re reading tags from a device (i.e. via Modbus or OPC UA server), you can create a custom view property which will store those values in a dataset or an array of objects and bind the data property of the table to that custom view prop.
Ok, so let’s suppose your input data is a list of dictionaries and each of those dictionaries have a key named path which contains the path of the tag you want to display the value of.
In a perspective table, create a column whose render is set to view and the field is set to path.
Then, create a new view. In the params of the view, make sure to declare the value parameter.
Place a label in your view, and create a indirect tag binding on the text property, and use the value params that you previously created in your binding.
Ensure the column you created in this table has the viewPath property set to the view you just created, and that the data property of the perspective table is set to the input data I mention at the beginning of my post.
This should work :slight_smile:
This might help re using a view in a table
Table Column Configurations | Ignition User Manual
