How to do tag export properly?
Hi
I am trying to rebuild the project in which gateway backup was faulty and designer launcher was not able to start even an empty project. I managed to uninstall ignition and then reinstall which gave me a brand new gateway to which i have imported the project backup. After some configuration regarding connections, tag providers and identity providers on both project and gateway the project can be launched and running.
Here comes the final important bit which is transferring all tags from the old gateway to the new gateway? Could you please advise me how to do it properly and what sequence to follow in that final step? there is no export all tags button which would be a help for me :slight_smile:
You just right click anywhere on the tag structure and choose export.
Create the file, then on the new gateway right click in the same place and choose import.
Browse to the file and select it.
tagexport
