Hi I write to you, because a need a guide to know how can I do for downloading a specific file from a BLOB table in MySQL.
I found how to insert or upload the file with system.db.runPrepUpdate() script but now, I need to downoload the file from the BLOB table.
Can you help me please with this problem?
I will appreciate it a lot
Best Regards
Carito
You can use the system.db.runPrepQuery function. Here is an example:result = system.db.runPrepQuery("SELECT Blob FROM Table WHERE ID = ?", [id])
if len(result):
blob = result[0][0] # You can now use the blob for whatever you want
system.file.writeFile("C:\\Some\\Path\\to\\File.ext", blob)
Thank you very much!!! Travis
It’s works very well
Best Regards
Carito
