how to download ignition hmi to hmi panel with ignition system
- Are you asking about Vision or Perspective or specifically the Ignition HMI product (as opposed to the Ignition gateway)? [Edited for clarity.]
- Where are you stuck?
This is irrelevant, isn't it?
You just need to restore the gateway onto the HMI. If you're unsure how to do that, then you should be starting with the Inductive University, as this is the most basic of basic fundamental parts to understand.
It is if the OP isn't aware that nothing has to be installed on a HMI client for a Perspective application (other than a browser). But maybe the question is about the Ignition HMI product specifically.
Oooh, yes of course. That was my tunnel vision assuming "download" meant running Ignition (GW) on the HMI (it's also late here...), but yes it could simply be a misinterpretation if wanting to run solely a Vision client or a Perspective client connected to a remote GW.
