How to draw P&ID in Perspectve?
Hello Everyone,
I am working on a project which includes drawing of P&ID in Perspective Ignition 8.3.
I am facing some alignment issues with the lines. My client specifically requires curvy lines not sharp cornered lines for better look and feel.
I am using drawing tool to make P&ID and i find it very time consuming and hard to adjust each and every line. And if i switch to tablet mode it still gets worst.
Is there a better altrenative way to do so?
If you want pipework aligned at different (even slightly) resolutions, do not use separate components for those rounded corners. As you've already seen, they will not remain aligned, unless you set the coord container to fixed mode so that it doesn't resize.
The only way you can do rounded corners which are resizable is by using an external vector tool (E.g. Inkscape or Affinity) to draw your pipes with rounded corners (I actually got Claude AI to write me a script to round corners in a cornered drawing which worked really well), and then import it into the view.
The most effective workflow for this type of project is to use an external SVG editor such as Inkscape. Start by taking a screenshot of your P&ID and importing it into the editor as a background reference. Then, create the SVG by tracing and drawing over the screenshot.
A key point is to set the document's measurement units to pixels (px). This ensures that when the SVG is imported back into Perspective, it maintains the correct scale and alignment.
Once the SVG is in Perspective, place your device Embedded Views on top of the SVG to provide interactivity while keeping the graphic itself lightweight and easy to maintain.
From a performance standpoint, this approach is typically around five times more efficient than using Perspective Pipes, especially for larger or more complex P&IDs. The trade-off is that the development workflow is slower and more manual compared to using the built-in Perspective Pipes tools, which can be faster for creating and modifying layouts directly within Perspective.
However, as the design becomes larger and more complex, the Perspective Designer can become noticeably laggy when using a large number of pipes and components. In those cases, creating the graphics in an external SVG editor is usually the better long-term choice, as it provides a smoother design experience and results in significantly better runtime performance.
I use embedded views
  1. Coordinate sized for my largest monitor (usually 1920x1080)
  2. Breakpoint
  3. Flex Row
  4. Flex Column
I use the breakpoint to determine when to switch from "Desktop" to "Tablet" to "Mobile Phone" orientations - horizontal or landscape.
For mobile, I'd be using a 3rd party pan and zoom container like BIJC's. Put the pan zoom container in the small breakpoint. It's a lot easier to use and more natural than a fixed size with scrollbars
I don't use perspective alot, this is from the one perspective project that I've done (2 years ago now). I'd take @nminchin 's advice over mine, but I am unfamiliar with those 3rd party modules.
well i showed my client both SVG Editing using inkScape as mentioned by nader and it did worked well for the curved linings. but as it is an additional skill to learn and also if we need to do some immediat changes it may take a while. So i have convienced my client to use pipe tool as is more handy and convienient.
So thanks a lot to everyone for the kind support.
If you have a pdf version of a P&ID, you can import it into Inkscape and trim out the extra bits. Be warned, initially this is massive and slow, once you take out the title blocks it will speed up.
If using piping tool (which I normally use, fwiw), always create a separate coord container to house the pipes, don't draw pipes on the same coord container as the symbols. It's an absolute pig fighting with infinite snap points
