How to enforce uniqueness across resources when the validator only receives config (no metadata)?
I’m writing a module that defines a resource type. The resource has two config fields (let’s call them fieldA and fieldB), and the requirement is that no two resources of that type can share the same combination of those values.
To enforce this, I’m registering a validator with the resource type:
public static final ResourceType RESOURCE_TYPE =
    new ResourceType(MODULE_ID, RESOURCE_ID_MY_RESOURCE);
public static final ResourceTypeMeta<MyResource> META =
    ResourceTypeMeta.newBuilder(MyResource.class)
        .resourceType(RESOURCE_TYPE)
        .categoryName("My Settings")
        .withValidator(new MyResourceValidator());
The validator looks something like this:
private static class MyResourceValidator implements ResourceValidator<MyResource> {
    @Override
    public Optional<ValidationErrors> validate(MyResource resource) {
        // check if (fieldA, fieldB) combo is unique among
        // all resources of type MyResource
The issue is that in the validate method I only get the config object (MyResource). I don’t get the resource’s metadata, such as name or enabled. That makes it tricky to enforce uniqueness, because:
  • When updating a resource, my check sees it as a duplicate of itself.
  • When fetching the resources with a GET, validation runs for each resource, and each one flags itself as a duplicate. This causes the response to include a JSON list of resources with metadata, but none of them have a config field populated.
If I had the resource’s name, I could skip the current one during validation, but since I don’t, every check ends up failing.
Is there a way to access the resource’s name from within validate, or is uniqueness supposed to be enforced somewhere else in the API? If the latter, what’s the correct way to do it? Is there another lifecycle hook I can use that fires before the resource is created and will still communicate a failed validation check back to the user like the validate method does?
I'm not sure the kind of uniqueness you are after is considered anywhere at all.
The validation API doesn't seem to consider the idea that validation of a decoded resource would consider any other resources. I don't think it was designed to.
You could maybe explore using a totally custom ResourceCodec (via DefaultResourceTypeMeta.Builder::withCodec), in which case you are going to be decoding a raw Resource, giving you access to some metadata. Not sure how it helps you know what other resources exist and determine the uniqueness of the field pair.
ValidationException is a DecodingException, throw it during ResourceCodec::decode at some point if you're able to determine it's not valid.
I should have provided more context: I have a singleton that has access to this resource’s NamedResourceHandler, which is how I’m able to check against existing resources. Thanks for pointing me in the right direction. I’ll take a closer look at using a custom ResourceCodec, since it seems to give access to the entire resource during decoding.
