How to export OPC DA data via OPC UA
Hello,
Our Ignition server connect DCS OPC-DA server (OPC protocal). I created tags and logged tag history in Ignition designer. Can I use 3rd party OPC-UA client connect Ignition OPC-UA server and export Ignition tags data?
Thanks,
Apisit
Yes. In the configuration of the Ignition OPC server, there is a setting called “Expose Tag Providers” that enables publishing of your SQLtags back out the OPC UA server to other clients.
