after declaring like this
def filter(self,tag):
if tag.name in self.myFilterFunction.split(','):
return false
getting this error
Try this:
return false
else:
return true
getting this error
global name ‘true’ is not defined
false and true need to be capitalized.
Sorry, typo.
return False
else:
return True
Your custom property is a string, not code. Don’t use quotes within it.
Hi, i have column containing string value
i am getting output like this [‘calcination temp’,‘weight’,‘wet weight - histogram’]
but actually i want like this calcination temp,weight,wet weight in single row- histogram
in order to pass this to my custom property - myfilterfunction in tag tree browser for filtering
how to query and get output like this calcination temp,weight,wet weight - histogram?
listIn = ','.join(newRows)
thanks got it
I Have tag tree browser
I am trying to hide folder common inside the line folder, but when i mention like this
if tag.name == 'Common':
return False
its hiding the all common folder in tag tree browser.
how to hide common folder only in inside of the Line folder?
You’ll have to filter on the path instead of the name.
if 'Line/Common' in tag.path:
return False
else:
return True
I’m just guessing at the path, you’ll need to verify that the path string is correct.
If you have more than one path, then you’ll need to develop a method for comparing against a list of paths.
given like this
but not hiding the path
still common folder is there
[MQTT Engine]Edge Nodes/Vidalengo/Line/Common
this is the full path i have given this also but its not hiding
yes tried but not hiding
so only checked with full path also. but that also not hiding
The tag object is of type com.inductiveautomation.ignition.common.tags.browsing.NodeBrowseInfo. You can’t get the path with tag.path. Need to use .getFullPath().
if `Line/Common` in str(tag.getFullPath()):
Its working Thanks a lot
You’ll have to loop through the .split().
