Can someone give me a clue how to find a character in a cell from a powertable.
I have tried this but it doesn’t work.
**string=self.data.getValueAt(rowIndex,'ALIMNAME1')**
if 'G' in string:
if colName == 'T2T' or colName == 'T2TH' or colName == 'T2_DIA' :
if float(self.data.getValueAt(rowIndex,'T2_DIA')) < float(self.data.getValueAt(rowIndex,'T2TH')):
return {'background': '168,0,0'}
Use hex values for your color. Also, I recommend defining a default set of colors at the beginning. It will make it more flexible if you add functionality:
config = {'background': 'white', 'foreground':'black'}
string = self.data.getValueAt(rowIndex,'ALIMNAME1')
if 'G' in string:
config['background'] = '#A80000'}
config['foreground'] = 'white'
return config
Thanks for you answer.
