I am in the process of migrating from MySQL to MSSQL, and I used the Tag Report Tool to track down which MySQL schemas were active for the Historical data... Apparently, I missed at least one tag, so when I removed the schema from MySQL, data forwarding errors began to rise. The Logs don't say which tag has an issue, so is there a place to look besides manually scraping through the list of tags?
Also, the tags that use the now defunct schema don't indicate an error, so that tells me there is no feedback from the Historian to the Tag proper that there could be a problem with the Historian DB Connection, correct?
