How to fit table row spacing
As you can see from the attached file.
I used the table from the perspective, but the rows have different spacing. Please let me know if you know how to match these spacing equally.
I think you mean "the columns have different widths".
You have two different tables - one with eight columns and one with seven so they are not going to look identical.
You can set column widths using,
props.columns.0.strictWidth : true
props.columns.0.width : 200
Do the same for each column.
