How to format a number in a report table
I have a report with two data sources - a static data source and a script data source. There are two columns - a name and a numeric value. They have the same data (within data type constraints).
I have displayed the data in tables. The value column is formatted as#,##0.
The static data is shown as expected - rounded to 0 decimal places and a thousands separator. The calculated data is not formatted.
Ignition 8.1.28
Screenshots (because I don't see a json export)
static_data
Meter, Value
"Static Meter 1", 32191.110980111298
"Static Meter 2", 8.1
script_data
def updateData(data, sample):
	header = ['Meter', 'Total']
	rows = []
	dataset = system.dataset.toDataSet(header, rows)
	data['Computed_Totals'] = dataset
	firstValue = 2343.123345234235623434
	secondValue = 34534.234325345534534563453
	total1 = secondValue - firstValue
	newRow = ['Calc Meter 1',total1]
	dataset = system.dataset.addRow(dataset, newRow)
	total2 = 8.1
	newRow = ['Calc Meter 2',total2]
	data['Computed_Totals']=dataset
toDataset defaults to string if no more specific type can be inferred from the data. Since you're not specifying a row, your column will be of type string, not a true number.
Just build your dataset last.
Thanks.
So when I was displaying type(newRow[1]) that was before the conversion. I should have displayed type(dataset[0][1]) instead.
And total2 = round(8.1, 0) was showing 8.0, so the automatic conversion defaults to one decimal place in that circumstance?
