How to get audit event timestamp in date and time
I'm facing the problem that my timestamps are not converted to date and time in my Named query. Can someone help me to convert it to a date and time instead of the timestamp value? I can't figure it out :frowning:
My namedquery is as follows:
SELECT
ae.event_timestamp AS Time,
ae.actor AS User,
ae.action AS Action,
ae.action_value AS Value,
case when ae.action='tag write' then
(select oae.action_value from AUDIT_EVENTS oae where oae.action=ae.action and oae.action_target=ae.action_target and oae.EVENT_TIMESTAMP<ae.EVENT_TIMESTAMP order by oae.EVENT_TIMESTAMP desc LIMIT 1)
else '' end as oldValue,
ae.action_target AS Target,
ae.actor_host AS Host,
ae.status_code AS 'Status Code',
ae.originating_system AS 'System',
ae.originating_context
FROM AUDIT_EVENTS ae
ORDER BY
ae.event_timestamp DESC
The timestamps in this table must be in date and time.
You will need to convert the value from unix epoch to get date and time.
Which DB are you using? I use this for MSSQL:
DATEADD(s, t_stamp/1000, '1970-01-01')
Thanks it helped me to get an idea, it now works with the following:
DATETIME(ROUND(ae.event_timestamp / 1000), 'unixepoch') AS Time
I use SQLite
Eww! You really should not. It is not designed for production, just to hold configuration data. If you need something free, use MariaDB or PostgreSQL.
Hi Stef,
I am having the same issue as you had.
Could you tell me where and how you inserted the code.
I am using SQlite as a database for and audit trail function.
My event time stamp is in milliseconds
I would appreciate any help.
Hi Stef,
Thank You.
