Pass column value to view in perspective table using a view render type
sample data :
will show check icon if true
This is the view i want to show in split column:
Thanks for any suggestion in advance! appreciated
There is no question in your post.
If you are asking how to add a component into a column then you need to create a small view with that component on it and embed that view in the table column. This is set in
props.columns.0.viewPath
for column 0, etc.
Hi, so what i want to do is to display this view in split column, my problem is I cant get the value on my data.
here’s my column settings
mySplit or whatever you like.view.params.mySplit.true or false value into viewParams.Well what data are you passing to the view?
I think thats what i need, i just followed this example in documentation and it did not work to me.
based on that example i shared, he got value parameter in the view and he just add the path in props.columns.0.viewPath and automatically get the data.
Check replies from cmallonee
This one fixed my problem.
