How to get last inserted row into a database table from a named query
I recall this being possible but I haven't been able to make it work.
I have a named query
INSERT INTO dbo.RecipeLog(RecipeDataID, UpdatedBy)
VALUES (:RecipeDataID, :UpdatedBy)
SELECT SCOPE_IDENTITY() AS LastInsertedID:
I would expect this to return 143 or whatever the last row inserted is (there is an auto incrementing primary key on the table) but it instead returns 1 (the first row).
I think last time I put the SCOPE_IDENTITY statement inside a stored procedure is why it worked. Is there a way to make this work inside a named query?
Use the getKey argument when running the NQ. You should not be using SCOPE_IDENTITY() yourself.
