How to get vision client resolution
Hello
Is there any way to get vision client session resolution?
Thanks Jordan
How about scaling factor in windows? For Hi Res Display 4K, windows impose some sort of scaling (200%). Is there any way to get scale factor?
Updated. Note this this doesn’t work in Java 8, as it always returns 100% scaling, for some reason. Java 11 seems to be okay. :man_shrugging:
import java.awt
gd=java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment().getDefaultScreenDevice()
width = gd.getDisplayMode().getWidth()
height = gd.getDisplayMode().getHeight()
dpi = java.awt.Toolkit.getDefaultToolkit().getScreenResolution()
tf = gd.getDefaultConfiguration().getDefaultTransform()
print 'resolution:', width, 'x', height
print 'dpi:', dpi
print 'scaleX:', tf.getScaleX()
print 'scaleY:', tf.getScaleY()
Hello Jordan,
Does this script go in the project startup section?
Thanks!
Hi Julio,
I think it could be placed about anywhere, although the startup script fires before there is any window open. I placed mine in the internalFrameActivated event of a window.
