I want to know how to use the drop down list. Is it possible to go to another window using the drop down list instead of using the buttons?
For example, I have two windows for Trends namely Trend 1 and Trend 2. I made two columns, both for string.
Col1 Col2
Trend 1 Trend 1
Trend 2 Trend 2
Col1 for the windows to open and Col2 is the display name. Now by selecting Trend 1 in the dropdown list, can I open the Trend 1 window? Please tell me how to do this?
All you need to do is add a propertyChange event to the dropdown list that opens a window when the user selects a different option. Add the following script to the propertyChange event handler:if event.propertyName == "selectedStringValue":
value = event.newValue
if value != "":
system.nav.openWindow(value)You can use the following to swap:if event.propertyName == "selectedStringValue":
if value != "":
system.nav.swapTo(value)If you get any errors post the full details of the error.
There is a problem with this script.
If I have several windows to select and i selected one of them before and then i returned to specific option again there is no new Value because it selected before.
How can I initialize selectedStringValue after clicked on it?
I am using this method to opening up windows. It works however I keep getting the following error message:
File “event:propertyChange”, line 8, in
ValueError: Window does not exist.
at org.python.core.Py.ValueError(Py.java:309)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:431)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:810)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:359)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:349)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:143)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:431)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at org.python.pycode._pyx0.f$0(<event:propertyChange>:13)
at org.python.pycode._pyx0.call_function(<event:propertyChange>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:180)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.access$000(ActionAdapter.java:40)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter$ActionRunner.run(ActionAdapter.java:286)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
