I have data displayed in a table that is collected every minute. I would like to sum the data, easy enough, and group by the hour portion of the t_stamp. How do I script the group by portion?
You didn’t mention what database you’re using, but in Postgresql, it would be something like:
SELECT to_char(t_stamp, 'YYYY-MM-DD HH24') as t_date, count(*)
FROM table
GROUP BY t_date
Note that I also used the date in the format string to keep dates separated.
If you don’t need to display the raw data, have your DB do the grouping and summation for you. If you want to group and sum without another DB round-trip, you might find the view() function from my Simulation Aids module helpful. Place something like the following as an expression binding on the 2nd table’s data property:
view("SELECT system.date.fromMillis(t_stamp[0].time - (t_stamp[0].time % 36000000)) As hour, "
+ "sum(someColumn) As sumOfColumn "
+ "GROUP BY t_stamp.time - (t_stamp.time % 36000000) "
+ "ORDER BY hour", {Root Container.Table.data})
I got it working by using this command:
group by DATEPART(hh, t_stamp)
order by t_stamp asc
Thanks for the advice, it is greatly appreciated.
