How to highlight button on another page in Ignition Vision with animation
Morning, everybody,
I'm making a template with side buttons to navigate the SCADA using Ignition Vision I would like, when I press a button on the "X" page, the corresponding button on the "Y" page changes color to signal that it has been pressed.
I tried:
event.source.background = system.gui.color(255, 0, 0)
and also with try/except blocks, but I couldn't get the desired result.
Also, I would like to implement something more dynamic than just a static background change: for example an animation when the button is activated, and that also reacts to the hover over the button.
At the moment I am not using tags to manage button status, but an Open/Swap page action.
Can anyone suggest the correct way to handle this behavior in Vision, possibly with smooth animations on the buttons?
Thanks so much in advance!
Read this topic for hover options:
For button styles, add a custom property to the button, bind your criteria, and use custom styles to change the color. Don't don't do it with scripts. I have a global menu system for all main windows. Since only one main window can be viewed at a time, I use a client tag integer that holds the value of the current window, bind that to buttons to highlight based on window open.
Consider using a docked window that holds all of your navigation, so you don't have to sync buttons across windows at all.
