Ok, this is my attempt at a how to. No pictures… yet. I am assuming you already have Ubuntu server installed. The commands will look a little different for previous version of Ubuntu server, and I will fill in those gaps at a later time.
- This step updates all packages currently installed on the server
sudo apt-get update
sudo apt-get upgrade
1b. Setup networking
sudo nano /etc/network/interfaces
for dhcp, keep the interface set as follows. Replace eth0 with the desired interface identifier.
# The primary network interface
auto eth0
iface eth0 inet dhcp
For Static Ip mapping
auto eth0
iface eth0 inet static
address x.x.x.x
netmask x.x.x.x
gateway x.x.x.x
Add an unprivileged user to run Ignition
sudo useradd -r ignition
- Install the java runtime and the zip utilities
sudo apt-get install sun-java6-jre zip unzip
3.download the Ignition executable stack. Replace xxxx with the build number you would like to use
For 32 Bit:
wget "http://files.inductiveautomation.com/release/buildxxxx/Ignition-buildxxxx-linux.zip"
For 64 Bit:
wget "http://files.inductiveautomation.com/release/buildxxxx/Ignition-buildxxxx-linux-x64.zip"
- Unzip software to the location of your choosing. I use /opt/ignition. Set permissions
sudo mkdir /opt/ignition
sudo cp Ignition-buildxxxx-linux(-x64).zip /opt/ignition/
cd /opt/ignition/
sudo unzip Ignition-buildxxxx-linux-(x64).zip
Set permissions
sudo chmod u+x ignition-gateway ignition.sh
sudo chown -R ignition.ignition .
Edit ignition.sh to allow unprivileged user to run ignition
sudo nano ignition.sh
Replace line
PIDDIR="."
with
PIDDIR="/tmp"
and line
#RUN_AS_USER=
with
RUN_AS_USER=ignition
- Symlink the startup script
sudo ln -s /opt/ignition/ignition.sh /etc/init.d/ignition
Enable startup script
sudo update-rc.d ignition defaults
6.Startup the service. For Ubuntu 9.10+, use the following command
sudo service ignition start
For 9.04 and before, use
sudo /etc/init.d/ignition start
- Browse to http://ipaddress:8088
That should be everything you need to get a working copy of Ignition working. I will add to this walkthough soon on how to install MySQl either from the repositories or from tar.gz. Also, I am looking a modifying the startup script to allow shutdown of the service, and running it as a different user.
