How to import UDT definition without removing any members not included in import file
Hello Gentlemen,
I have a client with whom I have 2 very very similar projects, differences being that a few valve/transmitters have been added in the second project. I ended up completing the first project, then cloning it with the differences in valves/temperature transmitters, etc.
The Client now wants some new QT960 ... QT964 transmitters added.
I have a MS_Base UDT Definition in both projects, and have added an additional 5 QT960 - QT964 UDT members in the first project. I want to be able to export this UDT Definition on the first project, and import only the new QT960 - QT964 while not removing some extra valves in that MS_Base on the second project.
When I try to import the MS_Base UDT, it will delete/remove some UDT members that only exist in the second project. I would like to match the other QT950 .. QT959 already in MS_Base
Is there an elegant way to selectively add some UDT members via import while not removing other needed UDT members? ( i.e. a couple extra valves )
I am using Ignition Vision v8.1 . I appreciate any help. Cheers
Not via any inbuilt method. what I'd do is to:
  • copy the tags from the UDT def in the tag browser into the standard tags into a new folder
  • Import the changed UDT into a new UDT def.
  • Copy those tags back into another new folder in the standard tags.
  • Copy those tags' json and import into the first new folder. That should replace all of the existing matching tag defs, add new ones, and keep any unmatching ones.
  • Then you can copy those tags back to the UDT def...
There might be some steps in that that can be shorter as I'm not at my laptop atm
Thank you. That method worked for me.
I wonder if IA will add that option when importing in the future i.e. keep existing members that were not included in the import file.
