How to install our own developed module in ignition 8 in without developer mode
how to install our own developed module in ignition 8 in without developer mode
You have to sign the module. If you intend to make the module public, you should use a code-signing certificate from a recognized Certificate Authority. If it will only be a private module, a self-signed certificate will suffice. Or a cert signed by a private CA.
You need the module signer utility.
