Hey guys....... ![]()
I am relatively new to the Ignition platform and am currently exploring ways to integrate it with AWS IoT for a project I'm working on. My goal is to send data from Ignition to AWS IoT and then process it further for analytics and monitoring.
I have read through the Ignition documentation and found some resources, but I’m still unsure about the best approach to take.
Is there a preferred method for connecting Ignition to AWS IoT? Are there any specific modules or configurations I should be aware of?
What steps do I need to follow to set up the connection? I’m looking for guidance on things like setting up AWS IoT policies, creating certificates, and any specific settings in Ignition that I should adjust.
I also check this: https://forum.inductiveautomation.com/t/issue-with-reading-string-tags-from-netlink-s7-drivermendix But I have not found any solution. Could anyone guide me about this? Are there any common pitfalls I should avoid? It would be great to hear about any challenges others have faced when integrating these two platforms.
Thanks in advance!
Respected community member! ![]()
