https://docs.inductiveautomation.com/display/DOC79/Tag+Quality+and+Overlays
Says that :
The following table outlines the primary data qualities. The most important is Good , and that has a value of 192 . There are more values, but these represent the most common:
We are currently working to correct a problem in our network introduced by our security team segmenting the network. The Ignition computer is able to reach out to a PLC via Kepware, and displays points that are monitored from the PLC , however, when the tags are created, they are created with Bad Quality.
It might help things if I could find out exactly what the ‘value’ is (as listed on the table in the linked page) but I don’t seem to be able to find it. Any help?
Answered:
The table is incomplete. ‘Bad Quality’ (among who knows what else) is not a quality that appears on the table of qualities. It ought to but does not. ‘Bad Quality’ represents a tag that is experiencing an unknown error. If your error can be diagnosed, you might get lucky and get a value that appears on the table, which will assist with troubleshooting. That’s why you’d be looking at a tag’s quality.
