How to make 'Acknowledge All' button
How do you make a custom 'acknowledge all' button? I'm sure there is a bunch of behind the scenes commands for alarm handling but I can't find anything obvious in the vision property editor
My best guess is something like system.alarm.acknowledge([*], '')
Also is there a way to prevent repeated instances of alarms from getting combined in the alarm history? If something triggers 4 times then I want to see those 4 instances separately even after its cleared and acknowledged
Cheers,
Zach
This is how i've done it in the past:
stringlist = []
list = system.alarm.queryStatus(state=["ActiveUnacked", "ClearUnacked"])
for id in list:
	stringlist.append(str(id.getId()))
system.alarm.acknowledge(stringlist,'', "admin")
It throws an error because it doesn't expect the 3rd argument in system.alarm.acknowledge() but otherwise perfect, thank you!
I ran mine gateway scoped, if you are doing it from the client then no third argument.
Golfed a little bit (and avoiding use of the builtin function names id and list):
ids = [str(event.id) for event in system.alarm.queryStatus(state=["ActiveUnacked", "ClearUnacked"])]
system.alarm.acknowledge(ids,'', "admin")
