Further to How to have a common date range across windows question.
[code]import datetime
ctEndDate has bi-directional binding to a calendar component.
endDate = system.tag.read("[Client]ctEndDate")
print endDate
results in: [Thu Mar 09 23:59:59 GMT 2017, Good, Thu Mar 09 12:20:38 GMT 2017]
[/code]
How do I work with this value to calculate time difference and output the result to another client tag? I understand (mostly) how timedelta works. The datetime functions don’t seem to understand the data format returned by system.tag.read.
endDate = system.tag.read("[Client]ctEndDate").value
@MMaynardUSG: That was the kind of prompt I was hoping for, thanks. I’m still missing something in my understanding.
import datetime
eDate = system.tag.read("[Client]ctEndDate").value
print "eDate.value: ", eDate
print "eDate year month day: ", eDate.year, eDate.month, eDate.day
results in
eDate.value: Thu Mar 09 23:59:59 gmt 2017
eDate year month day: 117 2 4
Why is this?
@pturmel: Thanks for the tips. I had an unsuccessful look around for an example of using the Java libraries. I’ll have to do some more research.
Java dates can be weird.
The year is the number of years since 1900. So if you print year+1900, you’ll be happier with the result
The month is 0 indexed, so the third month (March) is 2.
Day is actually day of the week. You probably wanted to print date.
The docs can be found at docs.oracle.com/javase/8/docs/a … /Date.html Personally I find it easier to use the Date to create a Java Calendar object and use Calendar’s constants to get what I want. But that’s probably because I’m a Java programmer, not a Python programmer.
Thanks, Kathy. I’m in business.
I’ve only one date-diff calculation to do for this project so I’ll stick with Python for now. Points about switching to Java are taken.
For anyone else this will work in the script console:
daysToSpan = 5
print "eDate year month day: ", eDate.year + 1900, eDate.month + 1, eDate.date
print "5 days span start date: ", datetime.date(eDate.year + 1900, eDate.month + 1, eDate.date) - datetime.timedelta(days = daysToSpan - 1)[/code]
… giving output …
eDate.value: Thu Mar 09 23:59:59 GMT 2017
eDate year month day: 2017 3 9
5 days span start date: 2017-03-05
And if I’d had enough caffeine this morning, I could also have recommended the scripting functions we provided to make this easier. (As I said, I’m a Java person not Python.
system.date.get* and system.date.add*
