The query below gives me the 3 category’s, the sum of hours for each category and the percentage. I have created new tables for a better table structure. I am trying to add joins to this current query for the new tables.
This is the original query
Select Category,
Hours,
100.0*Hours/(SUM(Hours) OVER (Order by Category ROWS BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING))Percentage
FROM (
Select Category, SUM(MaintTech1Hours + MaintTech2Hours + MaintTech3Hours + MaintTech4Hours + MaintTech5Hours) Hours
From WorkOrder
Where DateTm Between DATEADD(month, DATEDIFF(month, 0, getDate()), 0) and DATEADD(month, DATEDIFF(month, -1, getDate()), -1)
Group by Category
) subq
This is the query I am trying to get figured out. This has the new table structure.
Select c.Category,
Hours,
100.0*Hours/(SUM(Hours) OVER (Order by c.Category ROWS BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING))Percentage
FROM (
Select c.Category, SUM(b.Hrs) Hours
From EquipWorkOrder a
Join EquipWorkOrderHrs b
On b.EquipWorkOrderID = a.EquipWorkOrderID
Join Category c
On c.CategoryID = a.CategoryID
Join Equipment d
On d.EquipmentID = a.EquipmentID
Where a.DateTm Between DATEADD(month, DATEDIFF(month, 0, getDate()), 0) and DATEADD(month, DATEDIFF(month, -1, getDate()), -1)
Group by c.Category
) subq
When I run the new query I get a error which states " The multi-part identifier c.Category could not be bound"
I tried this but It gives me a syntax for " .". I am assuming because It doesn’t know what table Category is in. But when I add the letter for what table it is in I still get a syntax error
Select c.Category,
Hours,
FROM (
Join Category c
Join Equipment d
Group by c.Category
) subq.Category
Yes, your aliases ‘a’, ‘b’, ‘c’, and ‘d’ are only valid inside the subquery. The output columns of the subquery are then associated with alias you give the subquery itself.
Select subq.Category,
Hours,
100.0*Hours/(SUM(Hours) OVER (Order by subq.Category ROWS BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING))Percentage
FROM (
Join Category c
Join Equipment d
Group by c.Category
) subq
