How to negate a boolean Indirect Tag binding?
Is there a way to directly negate the value of an Indirect Tag binding?
When using an Expression binding, it's simple to invert a boolean by using the !. However, I need to use an Indirect Tag binding to dynamically construct my tag path, and I would like the resulting boolean value to be negated.
Thanks for any tips!
Directly, no.
Make a custom property with indirect binding and use that property in your expression...
Have you tried adding an expression Transform after your expression?
Vision doesn't have binding transforms.
