How to Open System Log file?
Hi All,
I just want to know how to open the exported system logs file (IDB File Type).
I tried to open it using SQLite but no luck. It says could not open database file.
Thanks.
SQLite3 ?
Hi pturmel,
Thanks for your reply.
I tried SQLite and SQLite Studio but it doesn’t recognize .idb as a file.
It says the file is not a database.
I pointed to SQLite3 because the version likely matters. Did you try SQLite version 3 ?
I’m using SQLite Version 3.12.2
and SQLiteStudio 3.3.3.
Are you sure the file downloaded completely from the gateway? IIRC, a truncated file won’t open.
Hi PTurmel,
Thanks again for your reply.
Is there a proper way to open it? Like change the file type to .sqlite?
On SQLiteStudio(3.3.3) > Add Database (Ctrl+O) > Database Type SQLite 3 Selected. > Browse IDB File from ignition gateway system logs (can’t able to browse since sqlite only supports .db , .sdb, .sqllite.
I also tried to change the file type so it can browse and select it but still no luck.
SQLiteStudio worked just fine for me:
You can choose ‘All Files’ in the file chooser to bypass the simple check for ‘known’ SQLite formats:
Opening using sqlite3 system_logs.idb seems to also work okay too if you’re on Linux…
https://asciinema.org/a/4c3Dn5Wwf7jf4uguUgcuyvJYF
Hi All,
Thanks PGriffith, PTurmel, and KCollins1 for your inputs.
The exported .idb file from Ignition Gateway doesn’t work. What I did was I went to the Ignition folder and get a copy of the system_logs.idb and it works. I’m not sure why does the exported file from Gateway doesn’t work.
Anyway, Thanks a lot!
Had same issue - thanks for the suggestion!
If you download logs from gateway please follow below steps,
Copy the file location path paste it in File option (Remove "" Quotation Marks)
Test connection it will work.
Note - I re-named downloaded file to "_logs"
Will the latest version of SQLite Studio (3.4.17) work for opening log files?
Presumably yes, but it's not IA software so I can't offer any guarantee.
Thank you, @paul-griffith. I asked because every time I need admin credentials to install software, it seems inappropriate to raise a request and provide a justification for each installation. That’s why I wanted to confirm before submitting a request for admin credentials.
