How to open windows application from ignition?
Good afternoon,
What would be the script if I wanted to open a windows program (for example skipe).
I have to link this action to a button on the scada.
Thank you
Take a look at system.util.execute.
You need to be careful as system.util.execute will launch new instances of the application each time.
We found this after having over 100 calculators open in the background :open_mouth::sweat_smile:
So we now issue a taskkill before the launch.
import time
system.util.execute(["taskkill","/f","/im","calc.exe"])
time.sleep(.5)
system.util.execute(["calc.exe"])
What if it is not a default windows app like for example -
C:\Program Files\uvnc bvba\UltraVNC.
Just pass it the full path to the exe
This should open each file or application exactly how the OS would.
import subprocess
subprocess.Popen(["C:\\Shared Gateway\\IgnitionTagHistory.pdf"],shell=True)
subprocess.Popen(["C:\\Program Files (x86)\\Google\\\Chrome\\Application\\chrome.exe"],shell=True)
thanks for your answer
I didn’t notice the double backslash at first. That should have been in the manual.
Thank you samngeru. This is exactly what I needed.
No problem.
This works fine for vision, how to open this from perspective.
You can't.
Allowing a browser to launch an OS application would be a major security flaw and therefore the functionality doesn't exist.
The closest you can get is to have an application pre- installed on the client machine that registers a custom URL protocol handler that opens that application. Similar to the way mailto:someEmailAddress?subject=someSubject launches Thunderbird on my workstation and starts creating a new message with that information.
(This is coming in v8.3 to launch Vision, Perspective Workstation, and Designers.)
