How to pass dynamic list of ids to name query params
Hello,
Like as code below I'd like to delete dynamic number of Ids from a table by using name query and I'd like to pass the ids list as params but I can't figure it out how to pass a list to name query.
DELETE FROM dependents
WHERE
employee_id IN (100 , 101, 102);
You can’t do it in a named query. You need to dynamically construct a “Prep” query in a script (with the correct number of question marks) to do this with safe parameters.
I do it in SELECT named queries all the time, it might work for deletes too.
Define a QueryString, employee_ids, of type String and adjust your where clause.
WHERE employee_id IN ({employee_ids})
That’s using a querystring, not a safe value parameter. Not the same thing at all.
To be fair, the OP didn’t ask for a safe way, just if there was a way. :slight_smile:
