How to pass value from Database (SQLite) to Internal Memory Tags
Hello all,
Good Morning,
Could you please help me how to pass the values from database table column values to Memory tags ?
Appreciated for your quick response with the simple solutions
Regards,
Srikanth P
Welcome!
Why a memory tag, instead of a query tag?
As I understood Query tag read from the database, I want to pass some data from the table on particular events if that I can achieve with Memory tag, that would be helpful for me.
Do you want to pass the entire table’s dataset to a memory tag of type dataset, or individual cells to individual tags?
Individual tags to Individual Memory Tags.
Tags to tags? I thought you were going table data to tags? If the latter, which columns and rows need to go to tags, all, albeit one at a time? Or just selected rows etc?
Table data
Example : If there is a table having 3 rows and 3 columns,
I want to pass first row first column table value from Database to Memory Tag (Float)
Consider transaction groups.
https://inductiveuniversity.com/videos/transaction-group-introduction/8.1
A query tag that writes to a memory tag in its tag change event seems pretty easy.
Thank you so much @Kevin.Herron
This way is very simple thanks for the reply with an great Idea
