How to perform a wildcard search and filter across a whole table with Named Query Binding
I would like to filter the test table below in Perspective by Text Field Input referencing UnitType and IssueType primarily, using a Named Query Binding or other method.
This MYSQL query using LIKE works fine in the console but I can't figure out how to reference the wildcard value in Perspective:
SELECT * FROM testPivot
WHERE  CONCAT(UnitType, IssueType)
LIKE '%Comms%' ORDER BY UnitType;
How do I dynamically reference the wildcard '%???%' in my named query?
I have tried several different methods with no luck, I basically want this:
SELECT * FROM
testPivot
WHERE CONCAT(UnitType, IssueType) LIKE '%TextFieldInput%'
I can filter the table by one input field such as this dropdown but adding additional parameters linked to the same input field doesn't work:
I have tried this also:
SELECT *
FROM testPivot
WHERE IssueType =:IssueType OR UnitType =:UnitType
Any reason you don't want to use the table's built-in filter ?
It will perform a like %foo% filter on all columns, so it will filter on both unit type and issue type.
It was just a layout idea I was trying, the built in filter is definitely the cleanest way to do it though thanks
I'm not totally sure I understand your question, but ....
You can just replace the search string passed to LIKE with a parameter:
LIKE :SearchString ORDER BY UnitType;
And then call the named query with "%Comms%", for example. If you don't want to have to remember the "%" on the caller, you can use LIKE CONCAT('%',:SearchString,'%') in the query and just pass "Comms" instead.
That's exactly what I wanted thank you, I just couldn't figure out how to reference the search string
I found a work around for what I wanted it's not very elegant but it works. I added a hidden 'Select All' column to my table and referenced that in my SELECT query. User can select a distinct issue type or 'Select All' in the drop down to filter the table.
SELECT *
FROM testPivot
WHERE (IssueType) LIKE :SearchString
OR (SelectAll) LIKE :SearchString
I'm still not sure why you're not just using the built-in filter.. What's the issue you needed to solve exactly ?
I am using the built in filter as well for additional filtering, I need to export data afterwards and the dropdown filter is for this
You can get the built-in filter results back for exporting too, take a look at the filter.results.enable and filter.results.data property on the table.
Thank you very much, I'll have a play around with that
