How to programmatically read the gateway version for a TagProvider
Hello, I would like to know how to programmatically obtain the version e.g 8.1.2 of a TagProviders gateway.
Kindly let me know if I need to provide any other info
You're missing a lot of context.
I assume since you don't already know the version, what you're actually after is the version from a remote gateway?
If you just care about the local gateway where your code is running, just run:
com.inductiveautomation.ignition.common.BundleUtil.get().getPlatformVersion()
Exactly, I am interested in the version of the remote gateway.
To provide context, I have observed that there are interoperability issues between v8.0.x gateways and v.7.x remote gateways. I want to check the local and remote versions and if there is a mismatch, log a warning to that effect.
Assuming you have a GatewayContext and a ServerId, you invoke the GanNodeDetailsService to retrieve a remote version:
                    var ganNodeDetailsService = context.getGatewayAreaNetworkManager()
                        .getServiceManager()
                        .getService(serverId, GanNodeDetailsService.class)
                        .get();
                    remoteVersion = Version.parse(ganNodeDetailsService.getPlatformVersion());
