How to pull changes from staging into designer?
I made a new pop up window a few days ago, along with a bunch of scripts/buttons/properties to go with it on the main window. I went to work on it today and the pop-up window is still in the project, but the changes to the main window are all gone. Luckily, I noticed that when I launch the Staging version the changes are still there.
I’ve tried clicking ‘Merge from Gateway’ but it didn’t change the main window at all.
How can I merge from staging or pull a staged change into my designer?
Any advice is appreciated! Thanks
My advice would be to use the gateway webpage at this point to export the staging project (from the Configure->Projects page). You could then re-import it (and then publish) or surgically retrieve the assets you need.
Thanks, that’s exactly what I was looking for
