How to read tag's quality on change event?
when I add this line of code (below) the script stops working.
if currentValue.quality != 'Good':
When I check the data type I get this below?
com.inductiveautomation.ignition.common.model.values.QualityCode
What type is currentValue.quality?
How do you check its value via scripting?
You can always use
currentValue.quality.good
You are trying to compare a QualityCode to a string, and theyre not equal
https://files.inductiveautomation.com/sdk/javadoc/ignition80/8.0.0-beta/com/inductiveautomation/ignition/common/model/values/QualityCode.html
Yes that seems to work
isGood and other methods are available (in some circumstances, at least) in autocompletion in 8.1.18:
oh my! excellent thank you!
Consider offering the property instead of the method for NetBeans-compliant getters. They are slightly more efficient. (One fewer jython-java thunk in each case: One property lookup instead of method lookup followed by function operator invocation.)
Ignition 8.1.1
I’m working in a UDT tag, Value Changed event. I cannot get the intellisense code completion dropdown like the one in your pic. I’m pressing (Ctrl)(Space) but it doesn’t present the enum?
Edit: I see where you mentioned v 8.1.18. It must be specific that newer version?
8.1.18 is still currently a pre-release “nightly” build - you’re sure that’s the version you downloaded?
Yes, you must be on 8.1.18, since that’s when this improved code completion landed. Full release is scheduled for ~mid June.
