I need to make a case statement or something to make this column human readable. But, want to make sure I am supplying right info. These are the distinct eventFlags in my table as well as their bin().
2 things… 1 is the bin() function on MySql give you the correct binary, is it read right to left or vice versa? and 2 is my description for int- 28 correct?
I don’t know about the MySQL thing, but I think you got it right.
If you can use a script, you could use something like that to avoid making the mapping manually for each combination:
def get_statuses(flag):
flags_map = [
"system event",
"shelved event",
"system acknowledgement",
"acknowledge event",
"cleared event"
return ", ".join(status for i, status in enumerate(flags_map) if flag & (1 << i))
