HI,
I am trying to read the alarm setpoint, enabled, displaypath etc… from a tag.
I am using the getConfiguration to find which tags have alarms then doing a tag read on the tapath.alarms.
it returns an ExtendedAlarmConfiguration object. Is this the right way to go about reading the alarm properties.
nodes = system.tag.getConfiguration(folder, True)
# Iterate over the results
for item in nodes:
# Through the results, search each dictionary
for key, value in item.iteritems():
# ...looking for a 'tags' key
if key == 'tags':
# iterate over the tag configurations we found
for tagConfig in value:
for conf in tagConfig:
if conf == "alarms":
filter = []
path = folder+"/" + tagConfig["name"] + "." + conf
p = system.tag.read(path)
print p
It’s all in the config.
nodes = system.tag.getConfiguration(folder, 1)
for item in nodes:
if key == 'tags':
# ...looking for a 'alarms' key
if 'alarms' in tagConfig.keys():
print tagConfig['name']
for alarm in tagConfig['alarms']:
for alarmKey in alarm.keys():
print ' ', alarmKey, ':', alarm[alarmKey]
# print alarm listing sparator
print ' ------------------'
# print tag listing separator'
print '______________________'
Note: This only shows configured items. If there is no displayPath key, there isn’t one set up. If there is no enabled key, it’s enabled.
with this solution it seems that this only returns the tag on the lowest level.
So I have a UDT with over 40 tags with 15 of them having alarms configured.
The UDT also has 4 folders with tags inside with alarms configured on a few.
The only tag that are returned are the ones in the folders.
This will recurse through the config
def iterTagConfig(dictIn, tab=0, folderIn = ''):
keys = dictIn.keys()
if 'tags' in keys:
keys.append(keys.pop(keys.index('tags')))
if 'alarms' in keys:
keys.append(keys.pop(keys.index('alarms')))
for key in keys:
if isinstance(dictIn[key], dict):
iterTagConfig(dictIn[key])
elif key == 'tags':
for tag in dictIn[key]:
print ' ' * tab,'tag'
iterTagConfig(tag, tab + 1, folderIn = folderIn + str(dictIn['path']) + '/')
elif key == 'alarms':
print ' ' * tab, 'alarms'
print ' ' * (tab+1),'alarm'
iterTagConfig(tag, tab + 2)
else:
if key == 'path':
fullPath = folderIn + str(dictIn['path'])
print ' ' * tab, key,":",dictIn[key],' fullPath =', fullPath
else:
for item in nodes:
iterTagConfig(item)
Hi Jordan,
What should be in the itertag function on line 9 instead of v?
Never mind got it working.
Thanks for the catch! Example updated.
