I’m posting this for anyone who may have a similar task - or a special CSS requirement for a table cell or column.
I keep a database of Engineering passwords for authorised users. Rather than have all the passwords visible to anyone looking over my shoulder I wanted to only reveal them one at a time on hover. Here’s how I did it.
- Set the table data query binding to Dataset.
- Add a Transform | Script to the query binding. Here’s mine:
ds = value
colNames = ds.getColumnNames()
d = []
for i in range(ds.rowCount):
rowDict = {}
for col in colNames:
if col == 'Password':
rowDict[col] = {"value":ds.getValueAt(i, col), "style": {"classes": "secret"}}
else:
rowDict[col] = {"value":ds.getValueAt(i, col)}
d.append(rowDict)
return d
- Create a style, secret in this case.
- Set the Base Style text to 2 pt. (This will be illegible unless the page is highly zoomed. I tried using transparency but couldn’t get it to change on hover. Someone may have a better idea.)
- Add Element State | Hover and set the text size to 12 pt (or whatever). Set colors if required.
- Leave both background colors empty / undefined.
If you examine the results in the table binding you’ll see the style object has been added to the Password column.
One question: I rather work with JSON but couldn’t figure out how to do this other than with a dataset. How could I have coded it for JSON?
