I’m new to FPMI and I just started experimenting with the FPMI Reporting Plugin. I used the Report Designer to create a report but I don’t see where I can save my report. If I just close the Report Designer and then go back into it my previous work is gone.
The report itself is a component in a window of your project. You should just hit OK on the report designer, and then be able to save your window. Are you closing the report designer with the red X in the upper-right of the window? This is equivalent to hitting “Cancel”
Hope this helps,
I knew it had to be simple. Now I see the OK button at the bottom of the Report Designer. I was closing the Report Designer with the “X” in the upper right corner of the window.
