I have a table which shows data from database, I want to open a pop up on clicking the row of the table with the details of that table row. How can I pass my row values to that view and how to retrieve it in that view.
Thank You.
Thank You.
Hi @ptchanchal,
You can see here how to pass parameter to a pop up.
https://docs.inductiveautomation.com/display/DOC80/Popup+Windows
Once you have your parameter inside the pop up, you can perform your CRUD,
then when you finish you may consider to use the function
system.db.refresh()
https://docs.inductiveautomation.com/display/DOC79/system.db.refresh
to update your table and show up your changes.
Grab your selected row elements from the table :
If you like to pass parameters from script :
window = system.nav.openWindow('TestPopUp', {'Int' : 40})
system.nav.centerWindow(window)
here we are opening a pop up called "TestPopUp", passing parameter as a Dict.
Thank you, I solved this issue by sending json file as message.
If you refer at this:
system.nav.openWindow('TestPopUp', {'Int' : 40} )
as
I think this Is a Python Dictionary, otherwise I'm curious to know how you passed parameter to a window as plain JSON.
I wrote the following code on the onRowClick event of the table:
messageType = ‘rowData’
payload = {‘rowData’: event.value}
scope = ‘session’
system.perspective.sendMessage(messageType, payload, scope)
on and script configuration of label in the other view, i created a rowData message Handler and selected listen scopes as session and wrote the following code:
self.props.text = payload[‘rowData’][‘employeeName’]
Oh i understand, you talking about Perspective sorry,
never worked on it yet,
my bad, I did’t pay attention on you tagging the post on perspective.
thats ok, you should try perspective its good
