How to set focus in perspective
I have a pop-up view in perspective that contains some labels, buttons and a textfield. I’d like to set the focus to the textfield when the pop-up opens, how can I do this?
Right-click the component and select Configure Events. Select the onStartup Event and supply the following code.
self.focus()
That’s what I’m looking for, thank you sir.
This method worked while we were on 8.0.12, but seems to have stopped working on 8.0.17. I am working with the same exact scenario as the OP (pop-up window, focus on text field onStartup). Is this fixed in later releases?
Oh, that’s interesting. I just checked in 8.1.6 and it’s not working there the first time the popup opens, but it is working on subsequent attempts. We’ll look into this.
I just tried to replicate this again and am unable to replicate the issue in any version after 8.1.6.
Currently, that script is working only for one time.
For example, if we are using a barcode scanner, when the value is entered automatically, the cursor disappears, and the next barcode can not be entered in the box unless the operator clicks on that box again. How can we write the code to run constantly and not only for one-time use?
That's expected, because it would only happen when the component gets created.
I would use this same approach (the onStartup Event usage) along with a value-changed script. Right-click the value for the props,text property of your TextField and select "Add Change Script...". Supply the same code: self.focus(). You might also need to set TextField.props.deferUpdates to have a value of false, and you might need to do the same for TextField.props.rejectUpdatesWhileFocused.
Do we have a similar approach in perspective? I am using version 8.1.6
That recommendation was for Perspective.
Thank you!
I was not able to find deferUpdate property and rejectUpdatesWhileFocused. I think this is because I am using numeric field not text field.
https://docs.inductiveautomation.com/display/DOC80/Perspective+-+Numeric+Entry+Field
And even though, I tried your method for text boxes as well. the cursor remains in that field, which is not what I am looking for. When the operator scan a barcode the cursor should appear at the beginning of the field for the next barcode. Currently, with your method, the new barcode value is added to the previous barcode value,
so now it is:
barcode 1: 12345
barcode2: 1234598765
but it should be:
barcode 1: 12345
barcode2: 98765
So then you need to modify the script to point to the “next” barcode. You should look into the Inductive University courses for Perspective.
Instead of self.focus(), you should be using something like:
self.getSibling("NumericEntryField_X").focus()
# modify "_X" to point to the next field
Thank you! I know how to point to the next field.
The application I am trying to do has one field only. By next barcode, I meant the next barcode that the barcode scanner scans.
So imagine I have one barcode:12345 and its field has a focus on it. when the barcode scanner scans the next barcode, the field should show the next barcode value, for example, 9876, but instead, it shows 123459876 (a combined value!)
As part of your change script, you will need to empty out the field.
# also do any sort of db write or change logic here before you wipe the value.
self.props.value = ""
self.focus()
Thank you! Unfortunately, the new barcode value is still added to the previous one and this is what I did:
First I created an event for that input component:
Then I wrote a script for edit property change script:
And then I assigned those two props to be false:
self.props.value = “” is not valid in your case
I put a binding on the enabled of the text box or numerical control.
For me it was a tag: [tags]Station0/State
Transform expression: {value}=110
Then put a change script on the enabled property of the text box or numerical control.
It was:
from time import sleep
if self.props.enabled:
sleep(1)
self.focus()
The issue for me was that I couldn't put the focus on an object while it was changing from a disabled to an enabled state.
Putting that sleep in there allowed it to change it's focus to itself after it had transitioned to enabled.
All you have to do is iterate that tag (Station0/State to be 111, in my case) to another value that you have the next box you want to look at. And change the new box to have a binding on enabled looking at this different number.
(tag: [tags]Station0/State Transform expression: {value}=111)
