What is the script to display date, one day before today(current date), for Date Range component?
for example I have this:
import datetime
date_component = system.gui.getParentWindow(event).getComponentForPath(‘Root Container.Date Range’).startDate
date_component = datetime.date.today() - datetime.timedelta(1)
Pat’s suggestion would be the only way to do this via scripting. I think the OP had also emailed in on this. The expression binding route would be the best method of doing what you want to do. If you set the polling time for now() to 0, such as now(0), it will only poll once when the window opens and that is all. With that being said, the first reply would be the best way to achieve what you are after.
