As above, how we can show labels on top of each bar in the XY graph.
Dear Yatika,
You have solved the solution for this ? we also stuck this points.
It looks as though you have four or more spaces at the start of the second line of your post. This is a Markdown instruction to format your text as code so the lines don't wrap. You can fix this by editing your post and removing the spaces. You can find more information here:
